Date/Time: Thu, 28 Nov 2024 01:36:46 +0000
Data Services
View Count: 393
[2022-12-07 15:13:37] |
User566571 - Posts: 1 |
Hello, i just want to use Sierra Chart for the only FOREX markets and Crypto markets. Which data pack do i have to get? Will appreciate for your help. Kind regards |
[2022-12-07 17:58:06] |
Will you be wanting to trade with LMAX or Interactive Brokers? If you will be trading from Sierra Chart, then you will need to be on one of the "Integrated" packages. Refer to the following: Description of Service Packages and Pricing: Integrated Packages Otherwise, if you are not going to be trading from Sierra Chart, then you can be on one of the "Base" packages and get the FOREX and CFD data. Refer to the following: Description of Service Packages and Pricing: Base Packages For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-06-07 13:21:19] |
User664528 - Posts: 1 |
SO basically, if you want to trade (e.g. with LMAX), you need to get one of the "Integrated" packages? "Base" packages are just analytic versions, no trading at all? Date Time Of Last Edit: 2023-06-07 13:21:28
[2023-06-07 14:05:57] |
Sierra_Chart Engineering - Posts: 17199 |
Yes that is correct.
