Date/Time: Mon, 31 Mar 2025 05:21:55 +0000
Invert direction for Interactive Scale Range - Expand/Compress Scale
View Count: 387
[2022-12-07 14:31:34]
MarkusK - Posts: 104
Hi, I have a quick question about the "Interactive Scale Range - Expand/Compress Scale" function:
It compresses the chart when I click & drag the mouse up, and it expands the chart when I drag the mouse down on the price scale.
Is it somehow possible to change this behavior and switch the directions, so that dragging up would expand the chart and dragging down would compress it?
I ask because the directions are exactly opposite to other tools that I use (e.g. Trading View), and it is often confusing when I use those tools and Sierra at the same time while trading.
[2022-12-07 17:27:59]
John - SC Support - Posts: 39026
There is not a way to change the behavior.
