Date/Time: Mon, 31 Mar 2025 05:17:36 +0000
TPO Peroid Lengh doesnt work
View Count: 343
[2022-12-07 14:08:48] |
TekinTrading - Posts: 8 |
Hi. I trade the HG Future and the Cash Time starts at 8:10 New York Time. However, after 30mins, no second TPO was created. If I change the Time Period Lengh to 40 or less 30, it works (it shows the second TPO builidng) What can I do? |
[2022-12-07 16:48:01] |
John - SC Support - Posts: 39026 |
Our guess is that this is related to the Evening Session settings. If you are using an Evening Session then the 30 minute periods are going to be based on the start of the Evening Session. If you want the periods to be based on the 08:10 starting time, then you will want to either not use an Evening Session (in Session Times) or set the TPO to have a separate Evening Session. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
