Date/Time: Tue, 26 Nov 2024 16:30:05 +0000
Alert Question
View Count: 1176
[2014-05-28 15:35:38] |
infpz - Posts: 826 |
Was trying to set up an alert when the last trade crosses the pivot point. I tried =CROSSOVER(ID1.SG13,LASTTRADE) but this generated an error. ID1.SG13 is the PP of the Pivot Point - Daily Study. Thanks, Patrick |
[2014-05-28 16:56:21] |
We do not receive an error with that formula. However, we recommend using: =CROSSOVER(ID1.SG13,C) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-05-28 16:57:12] |
OK, but does that wait till the bar closes to give the alert? I would like to happen immediately if possible.
[2014-05-28 16:58:19] |
It will happen immediately as long as you have not enabled Evaluate on Bar Close.
[2014-05-28 17:00:08] |
OK. I understand - I thought C was always implying it would wait for the close. But I can use C comfortably in most situations as long as Evaluate on Bar Close is not selected. Correct?
[2014-05-28 17:10:09] |
No. This means the close price of the current bar. Refer to: http://www.sierrachart.com/index.php?l=doc/doc_AlertCondAndScan.html#BaseGraphIdentifiers It will work as intended. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
