Date/Time: Mon, 31 Mar 2025 05:21:54 +0000
Trading System Based on Alert
View Count: 371
[2022-12-07 02:14:14] |
Infinite - Posts: 134 |
I have been using the Trading Stem Based on ALert. It uses MARKET orders. I opened and edited the C++ program to make all orders LIMIT saved it and built DLL with same exact NAME. I am using that Trading System Based on Alert on several charts, Without changing anything except creating new DLL, Will the Trading System Based on Alert be Automatically using the new DLL or do I need to erase and reADD each studies to graph for it to take effect? Date Time Of Last Edit: 2022-12-07 05:28:35
[2022-12-07 15:42:27] |
John - SC Support - Posts: 39026 |
Any existing "Trading System Based On Alert" studies will NOT be using your new version. Your new version is located in a different place, both on the file system and within Sierra Chart. To add your version of the study, you need to select the button for "Add Custom Study" on the Studies window and then find your particular DLL in that location. So you will need to remove the previous ones and add your new one to get the updates. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
