Date/Time: Mon, 31 Mar 2025 17:38:42 +0000
CFD-data IB
View Count: 492
[2022-12-06 19:54:27] |
User232165 - Posts: 25 |
My question regards to CFD trading on my IB account. I understood that sierra provides CFD data from FXCM. For trading on IB the right symbol for the IBM CFD woud be: IBM-CFD-SMART-USD-BAAVG, right? Do in that case the data come from IB or from FXCM. Thanks |
[2022-12-06 20:38:17] |
John - SC Support - Posts: 39039 |
We can not say what the correct symbol is. You would need to check with IB on that. We do not have CFD data for individual stocks, just for indices. Therefore the data for this would be coming from IB. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-12-07 00:06:34] |
Sierra_Chart Engineering - Posts: 19022 |
We activated your account so you can test. Refer to: Interactive Brokers Trading Service: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
