Date/Time: Wed, 09 Apr 2025 22:51:55 +0000
Recent Bid/Ask Volume not fully aligning
View Count: 474
[2022-12-06 19:26:27] |
User420511 - Posts: 4 |
Hey, two questions: 1. It seems I've tried everything, and I read all the threads before but the Recent Bid/Ask volume columns in the DOM is not fully aligning with the tick. The mind's blowing thing is that most of them are aligning correctly, but some, out of nowhere is not in the order to the price level. - Scale increment = 0,01 - Tick Size = 0.01 Those are the same size in Symbol settings as well. 2. Also, I want to ask about Footprint bid/ask volume data which has gaps in the middle of the session and it's pretty often, as you can see in the image. Is that normal for such liquid equity as SPY-NQTV or do I set something incorrectly? - I have SP-12 & NASDAQ US stock data activated Thanks a lot! |
Attachment Deleted. ![]() |
[2022-12-07 20:37:38] |
Sierra_Chart Engineering - Posts: 19117 |
1. We need some time to look into this. We are not sure about this right now. 2. Quite sure this is normal. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-12-07 20:37:54
[2023-01-06 19:52:16] |
1. We apologize for the long delay here. The tick size for SPY-NQTV is actually .005 and that is why you see what you do. It does not trade always in .01 increments but usually it does. Here is an example price: 382.275 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-01-06 19:52:58
[2023-01-06 22:09:05] |
Thanks for your reply. I see know, I understood. Same thing is with QQQ-NQTV. |
