Date/Time: Mon, 31 Mar 2025 05:18:48 +0000
Sierra chart Parallels
View Count: 342
[2022-12-06 16:10:40] |
giutello - Posts: 1 |
Hello Sierra Chart, I tried to install Sierra Chart on my Mac Book with Parallels but it doesn´t work. I always get the massage "Error saving downloaded files to local system. Stopping installation. Check log. Press install to retry." Do you have any solutions? I have installed Parallels Desktop 18 and the Mac Book Air with M1 from 2021. |
[2022-12-06 17:30:24] |
John - SC Support - Posts: 39026 |
The only solution we can offer is to use the Zip installer instead. Refer to the following: Software Download: Sierra Chart Zip Installer For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
