Date/Time: Mon, 31 Mar 2025 05:11:59 +0000
optimize hw resources
View Count: 349
[2022-12-06 12:40:37]
User499894 - Posts: 49
In order to minimize CPU and memory load:
1) Is it better to use the native VWAP study or display the desired VWAP applying a VbP study with all but VWAP subgraphs in IGNORE draw style?
2) If I have let's say 5 intraday charts of same symbol and each of them display the same VWAP (or other study with the same settings in each chart), what is the lighter solution between applying the study separately to each chart or applying it only to one and then overlay it to the others?
[2022-12-06 15:39:31]
John - SC Support - Posts: 39026
You would have to try the various options and look at he time to calculate the different options. On the Studies window on the right side where the list of studies is, each study has a time associated with it shown in 'ms'.
