Date/Time: Mon, 31 Mar 2025 05:24:30 +0000
importing trades
View Count: 811
[2022-12-06 03:13:16] |
coachted - Posts: 386 |
during thanksgiving weekend i was away and i traded on my laptop. These trades are not included in my trade log on my normal trading pc...yet today I traded i looked at my laptop and the trades i did today on my pc are showing up in my laptop trading log....how do i get the trades from my laptop that are missing in my pc trading log.
[2022-12-06 14:52:28] |
John - SC Support - Posts: 39026 |
The reason for this is because CQG does not keep the trade information for very long (we do not remember exactly the amount of time). Therefore, if you happen to connect from both systems within that time period, you will see the trades. Otherwise, they will not show up automatically. To get the information from one system to another you can export the Trade Activity Log on the one system and then import it into the other. It will not duplicate any existing fills, Refer to the following: Trade Activity Log: Importing and Exporting Data For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-12-07 18:04:06] |
JUST CURIOUS SHOULD I DELETE OUT THE REDUNDANT INFO FROM THE REPORT I AM GOING TO EXPORT?
[2022-12-07 21:34:21] |
No, you do not need to do that. When you import it, the system will ignore redundant data.
