Date/Time: Sun, 12 May 2024 07:56:05 +0000
Tool Values Window
View Count: 1731
[2013-04-30 19:37:12] |
apollofl - Posts: 95 |
Clicking on TVW and it will not open on Version 969...HELP!!!!
[2013-04-30 20:25:57] |
Select Window >> Reset Windows and open the Tool Values Window again.
[2013-04-30 20:35:31] |
Thank You, that worked.
