Date/Time: Mon, 31 Mar 2025 05:26:50 +0000
Incorrect opening window e.g. Horizontal line non-Extended Properties
View Count: 309
[2022-12-05 21:18:10]
T.Gerhard - Posts: 3
sometimes i have a technical problem, i want to do a left click with my pc mouse and i want to move a line in an other position, than a window is opening for example with horizontal line non-extended properties or something else. this problem disturbs my work process enormously, because it happens every 2nd or 3rd left click. Please explain, how i can solve this problem. thx Gerhard
[2022-12-05 23:33:39]
John - SC Support - Posts: 39026
Check your Tool Settings in general to make sure they are how you want them as there are a number of options that can affect how you interact with drawings. But in particular look at how you have the setting for Double Click on Drawing Brings Up Drawing Properties. Refer to the following:
Chart Drawing Tools: General Tool Settings
