Date/Time: Fri, 11 Apr 2025 21:03:21 +0000
Time and sales not displaying all trades
View Count: 951
[2022-12-05 19:20:29]
the white rabbit - Posts: 24
I have 2 tapes , the left is TOS and the right is SC.
they both have the same filters : Do not combine and volume >=15
as you can see the TOS shows some buy orders that SC's tape does not show.
I wonder what causes this.
Thank you
imageScreenshot (110).png / V - Attached On 2022-12-05 19:19:47 UTC - Size: 8.64 KB - 132 views
[2022-12-06 01:44:32]
Sierra_Chart Engineering - Posts: 19154
What symbol is this for?
[2022-12-06 07:42:35]
it is for the ES
I have the same discrepancy when comparing the SC's tape with Jigsaw .
Thank you
[2022-12-06 14:42:21]
This is a side by side comparison btw Jigsaw tape (left) and SC (Right)
same filters
Date Time Of Last Edit: 2022-12-06 14:44:12
imageScreenshot (111).png / V - Attached On 2022-12-06 14:44:03 UTC - Size: 26.92 KB - 130 views
[2022-12-06 15:25:35]
The first thing to do is to remove the filtering and then make sure you see all of the trades.
The filtering definitely works correctly and the data feed cannot possibly be missing any data. That is impossible.
[2023-01-06 18:54:35]
User500207 - Posts: 5
TIME and SALES question
With no filtering I see trades
When I input More or equal to ex 90 do not combine I see maybee 4 or 5 trades cash open to cash close
I am assuming I am doing something wrong compared to other apps showing 100+ thru out the day
denali feed ES minis
[2023-01-10 22:57:22]
This could very well be correct.
You probably will want to use this combining option (Combine Records into Exchange Reported Original Summary Trade):
Time and Sales Window: Combine Records >> Do Not Combine
Date Time Of Last Edit: 2023-01-10 22:58:04
