Date/Time: Mon, 31 Mar 2025 05:21:54 +0000
cant right click in chart
View Count: 550
[2022-12-05 18:06:40]
Maliks Bairamovs - Posts: 2
i cant right click in any of my charts , every thing else i can right click even the scales on my chart, except for the charts itself, it happend since i updated to the latest SC version
[2022-12-05 22:10:15]
John - SC Support - Posts: 39026
Select Global Settings >> Customize Chart Shortcut Settings and see if there are any items listed on the right side. If there are none, then you most likely are not getting the right-click options to show because you do not have any setup. Select the items from the left and move them to the right to make them available.
[2022-12-06 20:09:24]
there are, when i restart i can right click a couple of times but then it just stops to work
[2022-12-06 20:39:47]
Can you please attach a chartbook and your Sierra4.config file to this thread for us to take a look. Refer to the following for how to attach the files:
https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile
