Date/Time: Mon, 21 Sep 2026 18:57:02 +0000
SC Data Feed - No Market Depth Data for Eurex
View Count: 1579
| [2014-05-28 06:18:20] |
| Futurestrader77 - Posts: 126 |
Hi, I am missing the market depth for Eurex. I am getting this message for Eurex: "Market Depth data has been rejected for symbol: GBL-201406-DTB. Not authorized for market depth. | 2014-05-28 08:15:07" or "Market Depth data has been rejected for symbol: DAX-201406-DTB. Not authorized for market depth. | 2014-05-28 08:17:43" Could you please take a look into this? Thanks! |
| [2014-05-28 06:46:03] |
| AKR - Posts: 542 |
me too. seems still an issue with the data feed like yesterday. I do not see any depth in the dom.
| [2014-05-28 06:59:22] |
checking
| [2014-05-28 07:13:25] |
Now I am getting level 2 quotes. Thanks!
| [2014-05-28 07:20:07] |
This problem has been resolved. The reason for it is we did a software update, during the evening and this update had support for the new EUREX exchange fees. Those were meant to be released on June 1. So the particular EUREX exchange you are on, has no depth effective June 1 and the price drops to something like 15USD. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2014-05-28 07:35:19] |
And what I have to do to get level 2 quotes after June 1?
| [2014-05-28 07:36:10] |
At the end of the month cancel the current EUREX exchange that you have and at the beginning of the next month enable the new EUREX exchange you will see listed which includes market depth.
