Date/Time: Tue, 01 Apr 2025 01:54:55 +0000
Live Position Incorrect, Open Quantity Not Accurate,Order Mod Fail Does not Match Original
View Count: 440
[2022-12-05 00:59:20] |
User624595 - Posts: 242 |
SCv2457, TWS 10.20.1d, copied Sierrachart folder onto different machine than where position was initiated from. On new machine, getting these errors: 1. Trading chart and Trade window does not show current live position, says flat. 2. Trade Positions window shows correct position, but Trade Activity Log shows '(not accurate)' next to Open Quantity. 3. Modifying live order from Sierrachart on new machine gives error: "Trading message from IB: Order being modified does not match original order. Error Code: 105. ServiceOrderID: 911. InternalOrderID: 10420. | 2022-12-04 19:37:54.513 * Order modification failed | Order being modified does not match original order. Internal Order ID: 10420. Service Order ID: 911. Symbol: ZN-202303-ECBOT. Account: xxxx| 2022-12-04 19:37:54.513 * " No issue modifying order directly from TWS. Date Time Of Last Edit: 2022-12-05 01:16:27
[2022-12-05 01:07:29] |
User987654 - Posts: 70 |
IB changed the symbols for ZN. SC is working on it. Interactive Brokers has updated symbols for CBOT and COMEX futures |
[2022-12-07 14:53:19] |
Sierra_Chart Engineering - Posts: 19022 |
For existing positions and orders you are going to have various issues, when Interactive Brokers changes a symbol.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-12-07 14:53:47
