Date/Time: Tue, 11 Mar 2025 05:07:34 +0000
MakeHTTPRequest question2
View Count: 1459
[2014-05-27 23:38:42]
onnb - Posts: 662
I am seeing something strange and thought you might have an idea.
I have code that makes an http request.
When I call a url such as "http://www.sierrachart.com/ACSILHTTPTest.txt" it works just fine.
When I call http://localhost:8081/sc/ESM14 the call doesn't reach the server
When I type this same url into a browser address, the request returns just fine.
Could this be related somehow to the port?
[2014-05-27 23:45:28]
onnb - Posts: 662
I see its the port - can the port be configured somehow?
[2014-05-28 00:33:46]
Yes it can be, but just give us some time to work on this.
We do not want to make a promise as to when this can be done, but new HTTP request functionality is part of our active development right now.
[2014-06-05 15:33:00]
onnb - Posts: 662
-Dependency on the Microsoft HTTP (web browsing) operating system functions is being removed. This is almost complete. We got into serious trouble with this awful Microsoft functionality last week which prevented logins to our real-time exchange data feed for about an hour. There was also a short-term backend authorization issue at the time, but the unreliable Microsoft HTTP functions were the main cause.
The server processes which previously used these HTTP functions, no longer use them. They use our own developed HTTP functionality now. So the problem that caused that issue is now gone for good.
You mentioned that this might be done by the end of this week - can you provide any update on that?
[2014-06-05 16:50:07]
We will work on adding support for the port number.
[2014-06-07 02:10:26]
Alternate port number support for HTTP ACSIL requests will be out in version 1145 which will be coming out this evening.
[2014-06-07 03:05:38]
Due to a small problem we are working on, we will not be able to do the release this evening. It will be out Monday afternoon.
[2014-06-10 13:32:09]
onnb - Posts: 662
Any update on 1145?
[2014-06-10 16:15:59]
This has been released.
Please test using a different port number for HTTP requests and let us know if you see any issues.
Date Time Of Last Edit: 2014-06-10 16:16:15
[2014-06-10 16:20:35]
onnb - Posts: 662
does the port get passed in with the url like this ( http://localhost:8081/)?
[2014-06-10 16:37:20]
Yes.
[2014-06-10 16:49:59]
onnb - Posts: 662
Looks good so far. I got 1145 as a pre-release. Do you have ETA of a regular release with this?
[2014-06-10 16:50:29]
Should be by the end of the week.
