Date/Time: Tue, 26 Nov 2024 16:18:37 +0000
Export TPO/MP data
View Count: 1815
[2014-05-27 20:02:01]
vectorTrader - Posts: 86
I would like to export various TPO/MP to text files for further processing. Specifically, I would like to export the following data and would like to know if there is a way to export this to a text file at the end of the day...thanks
TPO and VOL Profile Information:
Period Start Date
First Price of Period
Last Price Date and Tine
Last Price of Period
Price Increment in Ticks
Total Number of TPO's
Price of TPO Midpoint
TPO Point of Control
TPO VA Upper Bound
TPO VA Lower Bound
TPO's above POC
PO's below POC
Total Volume
Price of Vol Midpoint
Vol Point of Control
Vol VA Upper Bound
Vol VA Lower Bound
Vol above POC
Vol below POC
IBR Upper Bound
IBR Lower Bound
TPO Mean
TPO Mode
TPO Median
[2014-05-27 20:48:41]
Some or all of this is outputted in a text format to a Spreadsheet when using the Spreadsheet study:
http://www.sierrachart.com/index.php?l=doc/doc_TPOVolProfileCharts.html#TextInformation
[2014-05-28 01:16:48]
Yes I understand that those values are available but only for the current day in the spread sheet. Is there a way to get them historically for past days? If not Is there a way to specify that the spreadsheet files saves in the data folder as a csv? This would allow someone to read the file at end of day and record them externally?
[2014-05-28 04:01:03]
No there is not a way to get them historically.
When you use File >> Save As you can change the file type on the Save File window and choose a text format.
