Date/Time: Mon, 31 Mar 2025 05:14:20 +0000
unmap certain chart
View Count: 450
[2022-12-03 17:21:19] |
User594974 - Posts: 35 |
I currently use Denali and recently wanted to test CBOE exchange data and compare it to my IBKR data from from CBOE only. Is there a way I can unmap a symbol for a certain chart only? Basically I want to see what some data looks like pulling from IBKR and not from sierra exchange CBOE data (only for a single chart). I don't know how to do this without making the change in Data/Trade Services which would affect mapping across the entire install. Is this possible? Thanks! |
[2022-12-03 18:09:01] |
Second Question. Is there a way to pull Option symbols straight from CBOE instead of using IBKR data? As you know their data sucks. The CBOE feed from Sierra is beautiful. Can I pull in individual option symbols to chart using this or another data feed other than IBKR that is better? I'm only interested in SPX SPXW options. Thanks! Date Time Of Last Edit: 2022-12-04 00:26:41
[2022-12-04 23:11:40] |
Sierra_Chart Engineering - Posts: 19004 |
Sierra Chart does not offer CBOE options in any way. No, but tell us what particular symbol?: Is there a way I can unmap a symbol for a certain chart only?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-12-04 23:12:25
[2022-12-05 00:39:48] |
Ok. Is there a way in the future that Sierra might offer CBOE options data? Even if it wasn't mapped to a trading service...that would be pretty cool. The symbol was just straight SPX index. Sometimes before adding the Sierra CBOE feed I would get a few gaps periodically. The CBOE data from Sierra cleared it up. BTW...thank you for continuing to keep IBKR as a trading service. |
[2022-12-05 22:11:44] |
No there are no plans for this: Is there a way in the future that Sierra might offer CBOE options data?
