Date/Time: Mon, 25 Nov 2024 16:36:52 +0000
[User Discussion] - Profile projected balance target
View Count: 965
[2022-12-03 00:38:30] |
OriolCasas - Posts: 163 |
Hello, I track imbalances of the profile, very simple study when there is a P shape on a profile there is bullish imbalance. Then you expect prices to move higher and balance the profile. When the profile is imbalanced (there is P shape) I would like to configure something so it tracks where the profile would get balanced (the projected balance target) You can see that on the picture attached. Is there any way I can configure the profile so it show the profile balanced target automatically? Thank you |
Projected balance target.png / V - Attached On 2022-12-03 00:38:26 UTC - Size: 44.71 KB - 203 views |
[2022-12-03 14:48:28] |
User427421 - Posts: 26 |
Verni does that by hand and it's not always based on the same conditions.
[2022-12-10 20:56:18] |
I know, but that's his system, not mine, for example Investor/Rt you can activate what I am looking for with a simple check option on the volume profile study. Any help from Sierra here? Thank you |
[2023-04-20 17:02:54] |
Letmein - Posts: 1 |
You can do it manually with the fib retracement, but having and auto PBT with the profile study would be nice.
[2024-02-17 03:47:54] |
User294671 - Posts: 3 |
Did anyone figure out how to auto PBT this?
