Date/Time: Tue, 26 Nov 2024 16:43:30 +0000
MakeHTTPRequest question
View Count: 1106
[2014-05-27 17:20:52]
onnb - Posts: 662
hi, I think you once mentioned that this method has some limitations and should not be called in parallel. I am assuming you meant that it should be called one at a time within the context of a study instance.
specifically:
If a study uses this method and the study is applied to several charts - is that safe?
[2014-05-28 08:46:30]
It is safe to use it from different study instances.
