Date/Time: Sat, 29 Mar 2025 05:37:13 +0000
Chart is black screen with no bars
View Count: 889
[2022-12-01 20:37:59] |
User978845 - Posts: 2 |
I am trying to use the trading sim on my trial account and setup a ESZZ22 chart but no bars are showing. I have tried my best to go through all the help topics, but nothing has seemed to work. Any help would be appreciated. Please see this screen image: https://www.sierrachart.com/image.php?Image=1669927028992.png
[2022-12-01 20:43:00] |
Sierra_Chart Engineering - Posts: 18981 |
The trial you are using is limited to certain symbols. Refer to: Sierra Chart Trial Account You can do a full activation through an SMS number. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-12-01 20:43:38
[2022-12-01 20:54:00] |
It works! Thank you so much!
