Date/Time: Mon, 25 Nov 2024 14:39:48 +0000
Show accumulated Bid/Ask Pulling/Stacking figures on Chart?
View Count: 1812
[2022-11-30 16:33:13] |
MarkusK - Posts: 99 |
Hi, I would have a quick question about the Bid/Ask Pulling/Stacking figures: I know that I can display the accumulated value for each in the DOM at the top/bottom of their respective columns, and that I can furthermore control how many levels are visible via the "Maximum Bid/Ask Market Depth Pulling/Stacking Levels". However, my problem is that the accumulated figures are only displayed at the top/bottom of their columns, and that I want to see more levels than fit on my screen. Therefore, I must constantly scroll the chart up and down to see the accumulated figures. Is there any way (maybe a specific study or something) that allows me to display the accumulated pulling/stacking figures somewhere else, maybe as a text on my chart? |
[2022-11-30 23:30:57] |
John - SC Support - Posts: 36243 |
The information can be viewed (and accessed) through the Numbers Bars Calculated Values 2 study. In particular, there are subgraphs for "Sum Bid Pull/Stack" and "Sum Ask Pull/Stack". Refer to the information here: Numbers Bars: Numbers Bars Calculated Values 2 Subgraph Descriptions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-12-01 03:44:40] |
Thanks a lot for the quick reply John. That is exactly what I was looking for!
[2024-02-24 18:03:04] |
vddfollow - Posts: 18 |
Dear support, Is there any way to display the sum of pulling/stacking, only for few levels in DOM ? Or it is just the total of depth level |
[2024-02-26 16:27:22] |
Refer to the following: Global Trade Settings Windows: Maximum Bid/Ask Market Depth Pulling/Stacking Levels (Global Settings >> Chart DOM Settings >> Other >> Other Settings) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
