Date/Time: Fri, 28 Mar 2025 12:48:52 +0000
Extension of the chart calculator
View Count: 358
[2022-11-30 11:17:39] |
User825944 - Posts: 5 |
Is it possible to program the ZigZag indicator to move individual reversal points manually. Or add more anchors to the Chartcalculator (A3, A4, A5), which will be switched on when needed. Then the Chartcalculator would also be usable for harmonic patterns. (X-A-B-C-D) Thanks |
[2022-11-30 14:50:57] |
Sierra_Chart Engineering - Posts: 18974 |
No, the Chart Calculator tool is not going to be expanded beyond what it is now. You can modify the zigzag study to meet your requirements: How to Build an Advanced Custom Study from Source Code Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
