Date/Time: Fri, 28 Mar 2025 12:51:33 +0000
Help With Indicator
View Count: 342
[2022-11-30 09:51:47]
rwilliams1 - Posts: 346
I'm trying to hedge two instruments and would like to chart what a proper hedge ratio would look like, but I'm not sure which indicator to use to accomplish this? For example, if I have 1 lot of January CL and would like to hedge it with 3 lots of September CL, what would I use to show their proper weights/strength? If I use a multiplier on one it simply multiplys the price; it doesn't show the proper weighting/strength of the ratio of the two instruments. Would I just use a simple ratio chart and change the multiplier, or something else?
Any help is appreciated.
[2022-11-30 23:59:42]
Sierra_Chart Engineering - Posts: 18974
We do not know what the math is that you would need to use to do what you want.
Have a look at the studies here to accomplish the calculations that you need:
Using the Basic Arithmetic Studies
