Date/Time: Fri, 28 Mar 2025 13:17:04 +0000
in log, connecting to ip question
View Count: 407
[2022-11-29 23:29:46] |
User686802 - Posts: 69 |
Hi, I have to split tunnel VPN when using my work laptop on the road, from my local sierra log file, I isolated the follow 3 domains and 4 ranges of ips. Is this comprehensive enough, am I missing something that would make entering these into split tunnel VPN (i.e., NOT go through corporate network) easier??? *.barchart.com *.sierrachart.com *.sierracharts.com 162.251.232.0/24 142.215.18.0/24 38.65.8.0/24 216.1.90.0/24 from my logfile: Search "Connecting to IP" (31 hits in 1 file of 1 searched) new 1 (31 hits) Line 271: Socket (2) | Connecting to IP: 162.251.232.235. | 2022-11-29 17:59:43.943 Line 274: DTC Client socket (5) | Connecting to IP: 162.251.232.235. | 2022-11-29 17:59:43.944 Line 281: DTC Client socket (6) | Connecting to IP: 142.215.18.125. | 2022-11-29 17:59:44.757 Line 286: DTC Client socket (7) | Connecting to IP: 38.65.8.115. | 2022-11-29 17:59:45.427 Line 480: Socket (1) | Connecting to IP: 142.215.18.105. | 2022-11-29 17:59:55.127 Line 510: Socket (1) | Connecting to IP: 142.215.18.104. | 2022-11-29 17:59:56.280 Line 550: Socket (1) | Connecting to IP: 162.251.232.235. | 2022-11-29 17:59:56.985 Line 581: Socket (1) | Connecting to IP: 142.215.18.105. | 2022-11-29 17:59:57.835 Line 609: Socket (1) | Connecting to IP: 142.215.18.104. | 2022-11-29 17:59:57.983 Line 635: Socket (2) | Connecting to IP: 162.251.232.235. | 2022-11-29 17:59:58.648 Line 670: Socket (1) | Connecting to IP: 142.215.18.105. | 2022-11-29 17:59:59.024 Line 708: Socket (1) | Connecting to IP: 142.215.18.104. | 2022-11-29 17:59:59.595 Line 745: Socket (1) | Connecting to IP: 162.251.232.235. | 2022-11-29 17:59:59.743 Line 773: Socket (1) | Connecting to IP: 142.215.18.105. | 2022-11-29 18:00:00.451 Line 797: Socket (1) | Connecting to IP: 142.215.18.104. | 2022-11-29 18:00:00.962 Line 826: Socket (1) | Connecting to IP: 162.251.232.235. | 2022-11-29 18:00:01.576 Line 853: Socket (1) | Connecting to IP: 142.215.18.105. | 2022-11-29 18:00:02.163 Line 878: Socket (1) | Connecting to IP: 142.215.18.104. | 2022-11-29 18:00:03.187 Line 907: Socket (1) | Connecting to IP: 162.251.232.235. | 2022-11-29 18:00:03.422 Line 946: Socket (1) | Connecting to IP: 142.215.18.105. | 2022-11-29 18:00:03.707 Line 976: Socket (1) | Connecting to IP: 142.215.18.103. | 2022-11-29 18:00:04.116 Line 1014: Socket (1) | Connecting to IP: 38.65.8.115. | 2022-11-29 18:00:04.833 Line 1044: Socket (1) | Connecting to IP: 38.65.8.115. | 2022-11-29 18:00:05.935 Line 1073: Socket (1) | Connecting to IP: 38.65.8.115. | 2022-11-29 18:00:06.373 Line 1103: Socket (2) | Connecting to IP: 38.65.8.115. | 2022-11-29 18:00:06.549 Line 1137: Socket (1) | Connecting to IP: 38.65.8.115. | 2022-11-29 18:00:06.786 Line 1171: Socket (1) | Connecting to IP: 38.65.8.115. | 2022-11-29 18:00:07.387 Line 1200: Socket (1) | Connecting to IP: 38.65.8.115. | 2022-11-29 18:00:08.156 Line 1228: Socket (1) | Connecting to IP: 142.215.18.103. | 2022-11-29 18:00:08.404 Line 1256: Socket (1) | Connecting to IP: 142.215.18.107. | 2022-11-29 18:00:08.993 Line 1285: Socket (1) | Connecting to IP: 216.1.90.129. | 2022-11-29 18:00:09.797 [end] |
[2022-11-30 04:18:54] |
Sierra_Chart Engineering - Posts: 18974 |
You just have to go through the Window >> Message Log and see what addresses are being used. We do not have the time to go through this. We do not know what is being used in your case.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-11-30 04:19:21
