Date/Time: Wed, 27 Nov 2024 08:42:21 +0000
General
View Count: 631
[2022-11-29 21:23:16]
User882391 - Posts: 90
Hello, whats the best way to link charts to show markings across price level on all types of charts i.e. TPO FOot Print Candle chart etc.
for example if i mark of Foot print chart @ price 4000 with Green Line, how can that be viewed on the same price in TPO chart or Candle chart for the same product. I seen user do it but cant find the appropriate setting to select from.
Thanks,
[2022-11-30 16:04:55]
Sierra_Chart Engineering - Posts: 17191
If you are using the Horizontal Line Tool, then refer to:
Copying Chart Drawings from Other Charts Automatically
[2022-11-30 16:19:30]
Thats it worked thank you
[2022-12-02 14:50:34]
For Sync trade, with Trade Chart Mode on.
1) Why doesnt the resting order show up across on 1 account and not the other?
2) I am placing trading on the dom and resting order would show up on The charts, but its not working currently in different accounts?
Thanks,
[2022-12-02 15:14:52]
1. We do not know what you are referring to.
2. We do not understand this either. However, refer to:
Chart Trading and the Chart DOM: Viewing Orders and Trade Position on the Chart / Trade DOM
[2022-12-02 15:23:06]
Is there a way to link Chart trading with Dom trading account
Thanks,
[2022-12-02 18:21:47]
John - SC Support - Posts: 36309
We are still not sure exactly what you are wanting to do, but refer to the information on linking the Trade Windows between charts:
https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#LinkNumber
[2022-12-02 18:31:33]
What part is not clear? this doesnt help me communicate with you
[2022-12-02 21:47:10]
This part is not clear:
What are you trying to link? What do you mean by a DOM Trading account? What exactly are you wanting to accomplish?
[2022-12-02 21:57:34]
So for trading account there is multiple account number and on Dom Account 1 is selected but Charts reflect different Account #'s. So is it possible to link DOM & Charts to Account # selected on the DOM.
I hope this is clear.
[2022-12-02 23:07:44]
If you have multiple trading accounts, then, by default, when you change the trading account on one Trading Window, it will not update to other charts. You would have to change the trading account for each chart.
The only way around this is to use Chart Linking with the option for the 'Trade Window' (as we mentioned above). Then, when you select a trading account on one Trade Window, it will update to all linked Trade Windows. Just be aware that all items on the Trade Window are linked, so if you do not want all the same items, then this may not be the solution you need.
[2023-02-17 19:38:57]
Hi John, on the Chart DOM how can change the size/font and column width of "Price Column". I am able to change other sections but the PRICE column.
Thanks,
[2023-02-17 22:37:21]
The Price Column uses the font for the Chart Text. Refer to the following:
Graphics Settings: Chart Text - (current font name)
You can not change the size of the Price column. The size is automatically adjusted based on the width of the data that is displayed.
[2023-09-04 20:51:28]
Hello John, can you please explain why i was being twice last month from Sierra 1)$54 and 2) $22
Thanks,
[2023-09-05 02:46:54]
You can find the transactions here:
https://www.sierrachart.com/UserControlPanel.php?page=TransactionLog
Date Time Of Last Edit: 2023-09-05 02:47:03
