Date/Time: Mon, 21 Sep 2026 12:54:33 +0000
PriceSquawk chart replay on Sierra chart
View Count: 922
| [2022-11-29 18:02:29] |
| User553413 - Posts: 63 |
I read a thread on the forum where the programmer linked this address <https://www.sierrachart.com/index.php?page=doc/DTCMessages_SierraChartCustom.php#Messages-REPLAY_CHART_DATA> in response to a question about adding the pricesquawk lader/dom to a historical Chart replay. Can you please give me more detail specifically on how to add this function to my Sierra chart during a replay so that I can practice hearing the flow of the market as as well as my strategy. Thanks.
| [2022-11-29 21:51:40] |
| Sierra_Chart Engineering - Posts: 24913 |
No, that is not going to work. Those messages are not connected with a chart replay.
| [2022-11-30 01:29:59] |
Is there any way that you can include this as an add-on feature for the sierra chart programmers to work on so that I wouldn't have to write the code from scratch to access the DTC server and make the client>>server connection to use the historical chart with the pricesquawk tool. I don't trust myself at the moment to go down that rabbit hole of learning the ropes of the sierra chart settings, especially if I have to learn a programming language. I've been procrastinating on that for many years. I would probably have a lot of bugs in my code :(.
| [2022-11-30 11:55:33] |
| Bango - Posts: 76 |
That would be very useful for troubleshooting the issue with Eurex data relaying through DTC server I think...
| [2022-11-30 14:52:26] |
No definitely there is not going to be any functionality ever to pass data from a chart replay through the DTC server. That is definitively never going to happen. That would be very complex to implement anyway. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-11-30 14:52:41
