Date/Time: Tue, 22 Apr 2025 07:33:23 +0000
Market Data and Historical Data Username and password
View Count: 493
[2022-11-29 17:29:55] |
bitzbytz786 - Posts: 11 |
Hi, I am setting up Apex and got Rithmic trading username and password. However when setting up Data/Trade Service settings, I am not able to set up the Market Data and Historical Data credentials. Can you help share the Market Data and Historical Data credentials associated with my Sierra Chart account. I am already paying for dual connection of Denali exchange feed. Thanks, S. Date Time Of Last Edit: 2022-11-29 17:30:04
[2022-11-29 17:37:53] |
Sierra_Chart Engineering - Posts: 19297 |
Those fields need to contain your Rithmic username and password. If you are using the Denali Data Feed, they can be left blank. They are not necessary. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-01-30 16:13:13] |
wallstreetsson - Posts: 77 |
Where is the market data username / Password field gone? I have to disable denali and only user rithmic, but it does not work. Any ideas? What are the symbols for Rithmic? In the list there is only ESH5.CME rn. Date Time Of Last Edit: 2025-01-30 16:30:51
[2025-01-30 17:02:26] |
With version 2727 and higher, Sierra Chart does not support data from Rithmic. Refer to the following: https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer2728 Thefore, you need to do one of the following: - Downgrade to version 2726 and use the Rithmic Data. Refer to the following for how to downgrade: Software Download: Full Control Rollback Procedure - Stay at the current version and use the data from our Denali Exchange Data Feed. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-01-30 17:16:17] |
Thanks this worked. Is this temporary or not to be changed in the future? Im using Denali anyway. |
[2025-01-30 17:58:41] |
This is a permanent change. We will not be supporting data from Rithmic going forward. We simply have had too many issues with it.
