Date/Time: Sat, 19 Apr 2025 12:00:26 +0000
Enable Order Allocation to Trade Accounts
View Count: 752
[2022-11-29 16:44:22] |
lservin29 - Posts: 67 |
In Trade Window > Settings > Enable Order Allocation to Trade Accounts...is there a way to make a hotkey for the feature to 'turn on' and 'turn off' with out having to click the "M" and scrolling via mouse? if not, would you consider adding this feature? |
[2022-11-30 16:26:06] |
John - SC Support - Posts: 39362 |
There are no shortcuts setup for this particular feature. We have set this as a Feature Request. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-11-30 23:50:36] |
Sierra_Chart Engineering - Posts: 19276 |
We will see about adding this. Should not be difficult.
[2022-12-01 03:06:27] |
ertrader - Posts: 682 |
Great idea and very helpful. Could it be updated in such a way that would enable us to add it to a control bar? That way, we could add a button to the control bar and click it with the mouse to enable or disable.
Date Time Of Last Edit: 2022-12-01 03:09:32
[2023-01-17 16:36:04] |
Hi any progress or updates on when this will be available as a hotkey or right click chart enable/disable thank you |
[2023-01-31 18:15:07] |
In SC 2478, the ability to add a control bar button to enable/disable order allocation was added... working great! Saves unnecessary menu picks and can see allocation status without doing anything. Thank you!
Date Time Of Last Edit: 2023-01-31 18:17:03
