Date/Time: Fri, 28 Mar 2025 12:48:52 +0000
[Programming Help] - How to get th bid/ask values at numbers of bar order flow
View Count: 400
[2022-11-29 06:25:57] |
User856576 - Posts: 4 |
Hi, I would like to do sum calculations and checks on the bid ask at the order flow chart on each contract on different price. How can i get this information to spreadsheet or to ASCIL function? I want to check the ask/bid as i marked in yellow at the pic attached below. |
[2022-11-29 18:28:34] |
John - SC Support - Posts: 39009 |
For what you are wanting, you will need to use ACSIL to get to the data. Refer to the following: ACSIL Programming Concepts: Accessing Volume at Price Data Per Bar For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
