Date/Time: Sat, 30 Nov 2024 05:33:05 +0000
Daily P/L not showing in trade window
View Count: 652
[2022-11-28 22:52:02]
TriStar Trading - Posts: 142
I have a chart window with an attached trade window that displays the account number but not the associated trade P/L or daily dollar and points etc. Any ideas anyone? It used to display.
[2022-11-29 04:27:56]
Sierra_Chart Engineering - Posts: 17268
Check the Profit/Loss Format setting:
Chart Settings: Profit/Loss Format (List) (Chart >> Chart Settings >> Trading menu)
[2022-12-12 17:38:13]
User146848 - Posts: 121
I have the problem that profit/loss value is wrong. I checked the symbol settings for corn and the tick value is as it should be: $12.5 / tick.
The profit/loss format is set as currency value (C). Yet, 1 tick gets shown as $1.25. For me personally there are numerous other symbols with this kind of problem.
[2022-12-12 18:59:52]
John - SC Support - Posts: 36350
When you checked the Currency Value per Tick were you looking at the Global Symbol Settings or the Chart Settings?
The value that is used is the one in the Chart Settings. Make sure that is set properly. If you are getting $1.25 per tick, then the value for Chart >> Chart Settings >> Symbol >> Currency Value per Tick must be set to 1.25.
