Date/Time: Fri, 28 Mar 2025 12:43:43 +0000
Whats the difference between USDX and USD-X ???
View Count: 495
[2022-11-28 22:33:59] |
User146848 - Posts: 124 |
see title
[2022-11-30 09:15:59] |
DEAR SC, whats the difference between the following two symbols: USDX and USD-X ? Thank You |
[2022-11-30 14:38:47] |
Sierra_Chart Engineering - Posts: 18974 |
USDX is the standard US dollar index. How USD-X is calculated is documented here: Sierra Chart Market Statistics Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-11-30 14:38:59
