Date/Time: Tue, 26 Nov 2024 15:35:19 +0000
Real time data not available
View Count: 1170
[2014-05-27 15:47:30] |
User47998 - Posts: 1 |
Hi, I can´t connect to your datafeed. Now, I have no money on my aditional acc balance, but datafeed is aviable till the end of the month, right? Thank for your answer. Tomas Studeny Error received in OnConnect while connecting. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2014-05-27 17:40:30 SC Exchange Data: Disconnected from the server. | 2014-05-27 17:40:30 SC Exchange Data: Data feed disconnected. Will reconnect. | 2014-05-27 17:40:30 Using username 0 | 2014-05-27 17:40:32 SC Exchange Data: Connecting to the server scdf1.sierracharts.com. Port 443 | 2014-05-27 17:40:32 Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2014-05-27 17:40:32 Error received in OnConnect while connecting. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2014-05-27 17:40:33 SC Exchange Data: Disconnected from the server. | 2014-05-27 17:40:33 SC Exchange Data: Data feed disconnected. Will reconnect. | 2014-05-27 17:40:33 Using username 0 | 2014-05-27 17:40:35 SC Exchange Data: Connecting to the server scdf2.sierracharts.com. Port 443 | 2014-05-27 17:40:35 Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2014-05-27 17:40:35 Error received in OnConnect while connecting. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2014-05-27 17:40:37 SC Exchange Data: Disconnected from the server. | 2014-05-27 17:40:37 SC Exchange Data: Data feed disconnected. Will reconnect. | 2014-05-27 17:40:37 Using username 0 | 2014-05-27 17:40:39 SC Exchange Data: Connecting to the server scdf1.sierracharts.com. Port 443 | 2014-05-27 17:40:39 Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2014-05-27 17:40:39 Error received in OnConnect while connecting. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2014-05-27 17:40:41 SC Exchange Data: Disconnected from the server. | 2014-05-27 17:40:41 SC Exchange Data: Data feed disconnected. Will reconnect. | 2014-05-27 17:40:41 Using username 0 | 2014-05-27 17:40:43 SC Exchange Data: Connecting to the server scdf2.sierracharts.com. Port 443 | 2014-05-27 17:40:43 Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2014-05-27 17:40:43 Error received in OnConnect while connecting. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2014-05-27 17:40:44 SC Exchange Data: Disconnected from the server. | 2014-05-27 17:40:44 SC Exchange Data: Data feed disconnected. Will reconnect. | 2014-05-27 17:40:44 Using username 0 | 2014-05-27 17:40:46 SC Exchange Data: Connecting to the server scdf1.sierracharts.com. Port 443 | 2014-05-27 17:40:46 Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2014-05-27 17:40:46 Error received in OnConnect while connecting. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2014-05-27 17:40:48 SC Exchange Data: Disconnected from the server. | 2014-05-27 17:40:48 SC Exchange Data: Data feed disconnected. Will reconnect. | 2014-05-27 17:40:48 Using username 0 | 2014-05-27 17:40:50 SC Exchange Data: Connecting to the server scdf2.sierracharts.com. Port 443 | 2014-05-27 17:40:50 Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2014-05-27 17:40:50 |
[2014-05-27 19:03:03] |
This problem was resolved earlier today.
