Date/Time: Fri, 28 Mar 2025 06:57:32 +0000
way to disable crash reporter?
View Count: 371
[2022-11-28 19:31:37]
User686802 - Posts: 69
Hi, i search on support board for "crash reporter false" got zero hit, meaning no one can disabled it? I am not concern about crash, i just want minimal stuff loaded and running. If there is setting or startup flag to disable crash reporter, please share!!
thanks
[2022-11-28 21:00:00]
Sierra_Chart Engineering - Posts: 18970
That program does not cause any resource issues but just simply delete the file and it will not run and we will make sure it does not run in the next release if it is not specifically being used.
It is extremely rare that we ever have to rely upon that program. It is used to troubleshoot some difficult problems. But those kinds of issues are quite rare.
Date Time Of Last Edit: 2022-11-28 21:00:06
[2022-11-29 00:42:40]
Upon further contemplation there is not a way to disable this, and it has zero impact upon performance. Nothing. It has no performance or overhead at all.
