Date/Time: Fri, 28 Mar 2025 13:07:48 +0000
Draw arrow on a chart using data from another chart
View Count: 377
[2022-11-28 19:30:27] |
maxima120 - Posts: 144 |
I have 2 charts, chart 2 has 2 studies. I want to draw an arrow on chart 1 when studies on chart 2 cross each other. Is there a simple way to do so, without writing custom ACSIL? |
[2022-11-29 17:25:06] |
John - SC Support - Posts: 39009 |
We need you to post on the Support Board with your active Sierra Chart account. To do that select "Help >> Support Board " from within Sierra Chart. If you did not get an answer to your prior question, post here again after doing the above confirming that you have logged in with your current account to let us know. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-11-29 17:25:23
