Date/Time: Fri, 28 Mar 2025 12:41:13 +0000
Trading Dom - Sum of Bid pulling and stacking
View Count: 1322
[2022-11-28 18:14:38] |
User513390 - Posts: 49 |
Dear Support Team. This morning I'm not seeing the Sum of Bid pulling and stacking, would you please guide me how to set it up? Thanks Rodney |
[2022-11-29 00:04:07] |
John - SC Support - Posts: 39009 |
If you are not seeing it in the Numbers Bars Calculated Values, then the most likely reason is that you do not have the Pulling and Stacking columns displayed. Once they are displayed, it is possible to remove them, and you will continue to get the information, but if you exit Sierra Chart and start again, then you may not get the data for Pulling/Stacking, therefore you need to re-add the columns. If you are not seeing the totals in the Pulling/Stacking columns themselves, then make sure you compress the scales far enough that you see all the Pulling/Stacking levels. If you want to control the number of Pulling/Stacking levels, then refer to the following: Global Trade Settings Windows: Maximum Bid/Ask Market Depth Pulling/Stacking Levels (Global Settings >> Chart DOM Settings >> Other >> Other Settings) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-11-30 08:18:49] |
Hello, I have remove them, exit Sierra Chart and start again. I cannot see... |
![]() Attachment Deleted. |
[2022-11-30 17:52:49] |
Check the setting for Graphics Settings >> Trade DOM Total/Percentage Text and ensure that this is not set to the same value as the background. Refer to the following: Customizing Fonts, Colors, Line Styles, and Widths for Chart Trading, Chart DOM, and Trade DOM: Trade DOM Total/Percentage Text Also be sure to set the scales to show a wider range and to see if the sums are actually showing, just further out then you expected. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
