Date/Time: Tue, 22 Sep 2026 08:19:21 +0000
Trial
View Count: 1094
[2022-11-28 15:09:42]
User442792 - Posts: 9
Hi, Ive tried activating my trial account through the phone number but i sent it and the sms verification code didnt come. What should i do?
[2022-11-28 17:39:47]
John - SC Support - Posts: 47955
We see that the trial has been activated for your account, so you are fine now.
[2022-11-28 17:48:03]
Its showing Not Connected and my charts are not loading, what should i do, so it activates in sierra charts?
[2022-11-28 17:52:18]
Select File >> Connect to Data Feed. If that option is greyed out, then that means that you are already connected.
From there, refer to the following for how to open a new chart:
Getting Started, Opening Charts and Basic Trading: Open A Chart
[2022-11-28 18:02:38]
I click on that and nothing happends, only message log opens,Panel is still red and saying Not Connected
[2022-11-29 00:00:38]
Please post your Message Log to this thread after you select File >> Connect to Data Feed by following these instructions:
[2022-11-29 08:02:52]
Ok, nothing happends only this.
imageConnect to data feed.png / V - Attached On 2022-11-29 08:01:32 UTC - Size: 9.81 KB - 215 views
[2022-11-29 13:55:36]
Sierra_Chart Engineering - Posts: 24928
What Data or Trading service are you trying to connect Sierra Chart to? Please be aware of these limitations for a trial:
What is Included in the Free Trial?: Data
Date Time Of Last Edit: 2022-11-29 13:55:58
[2022-11-29 14:04:25]
I started sierra chart now, and it strated working, The box that said Not Connected is now green so i gues everything is ok now. Dont know where was the problem but thank you John :)
[2022-11-30 23:49:53]
Your account previously may not have been activated but that was done.
