Date/Time: Fri, 28 Mar 2025 11:26:55 +0000
Set Limit Orders to Break Even?
View Count: 326
[2022-11-28 02:25:13] |
User280673 - Posts: 27 |
Is there a way to set active limit orders to break even without manually moving them? If not, would it be possible to add this feature? Either a hotkey or button would be ideal. Essentially, limit order > break even command. |
[2022-11-28 09:56:07] |
Sierra_Chart Engineering - Posts: 18974 |
This is not exactly what you want but there is this command: Order Types: Move Attached Targets to Price Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
