Date/Time: Fri, 28 Mar 2025 11:18:25 +0000
Conversion of old templates
View Count: 517
[2022-11-27 16:54:16]
SFJ - Posts: 7
Hi
Could you kindly convert the attached old templates
attachmentSTAGE1PROFILECHARTBOOK-200608-010449.Cht - Attached On 2022-11-27 16:53:12 UTC - Size: 23.05 KB - 304 views
attachmentSTAGE2FINALCHARTBOOKCLONLY-200608-010527.Cht - Attached On 2022-11-27 16:53:16 UTC - Size: 16.59 KB - 103 views
[2022-11-28 02:00:22]
Sierra_Chart Engineering - Posts: 18974
You are able to do this on your side.
Refer to the instructions here:
Chartbooks (Workspaces): Opening Older Chartbooks
