Date/Time: Fri, 28 Mar 2025 13:38:24 +0000
color BAR in chart
View Count: 466
[2022-11-27 16:38:25] |
User929820 - Posts: 2 |
hi how color only long up BAR or long dow bar in the chart and add a alert on each thank you so much excuse me for my english |
[2022-11-28 09:55:18] |
Sierra_Chart Engineering - Posts: 18974 |
You can do that with this study: Color Bar Based on Alert Condition Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-11-28 22:26:37] |
i want color only the long down and long up ohlc bar in the chart thank you |
[2022-11-29 17:57:00] |
John - SC Support - Posts: 39009 |
The study linked above gives you that ability. Follow the instructions on that page to create an Alert for when you have a "Long Down" bar and then it will get colored. Also refer to the information on Alerts at the following link: Study/Chart Alerts And Scanning Note that if you want different colors for the "Long Down" versus the "Long Up" then you will need to use two copies of the "Color Bar Based on Alert Condition" study to cover each situation separately. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
