Date/Time: Fri, 28 Mar 2025 07:09:03 +0000
sharing live Denali data feed on multiple instances of Sierra on the same computer
View Count: 416
[2022-11-26 22:27:52] |
User467500 - Posts: 28 |
i saw on Sierra Chart Purchase and License Information: Licensing / Number of Systems that i can run 3 instances of SC on a single computer. Can all 3 instances also use my live denali data feed? Thanks |
[2022-11-28 16:46:04] |
John - SC Support - Posts: 39009 |
Actually the licensing for the Sierra Chart software is such that you can run as many versions of the software on a computer as you want. You can also have Sierra Chart running on 2 computers simultaneously without the need to pay additional fees. You can pay for and have a total of 4 computers running Sierra Chart at the same time (again with as many installations on each computer as you want). But, the data feeds have different rules since we have to follow what the exchanges want. The Denali Exchange Data Feed can only have 3 connections from a single computer at a time, and you can only have 2 computers accessing the data at the same time (which requires an additional exchange fee payment for the second computer). For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-11-28 16:53:41] |
Thanks. So what i hear is that if have no more than 3 instances of SC running on the same PC ( personal trading acct + 2 prop firms, resources permitting),i can use my denali feed for all 3. gracias!
Date Time Of Last Edit: 2022-11-28 16:54:29
[2022-11-28 17:50:21] |
That is correct. Refer to the information on Denali Connections at the following link: Denali Exchange Data Feed: Connections Note that the above documentation states 2 connections, but we recently changed this to 3. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
