Date/Time: Tue, 26 Nov 2024 16:29:01 +0000
Can not connect to IB
View Count: 1161
[2014-05-27 15:27:19] |
HalGE - Posts: 39 |
After paying up, seems like the gods of pc's still dont like me... CAN NOT connect to IBs TWS The sierra log says Error recieved in OnConnect while connecting Windows error code 10061 No connection could be made because the target machine actively refused it I coppied that from the trading pc Message log and wrote it here in the laptop... I did NOTHING over the weekend with that pc... and it did connect earlier today... just now it started refusing to connect... and I dont get the new data feed either... eddit... I just noticed the GREEn background box near the upper right corner of the sierra screen says DF then a 4 digit number htat keeps increasing and ST 7 does that mean the Data Flow is flowing to sierra? I checked to see if I was using the lateset TWS... and I am How do I fix this ?? Date Time Of Last Edit: 2014-05-27 15:44:50
[2014-05-27 20:50:16] |
This problem was resolved earlier today. Most likely you were experiencing a problem connecting to the Sierra Chart Exchange Data Feed. Let us know if you still have a problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
