Date/Time: Fri, 28 Mar 2025 11:18:25 +0000
Numbers bar calculated value- color background based on value percentage for all data.
View Count: 357
[2022-11-26 10:18:36] |
User238343 - Posts: 20 |
Values are colored based on percent compare thresh holds 10% 25% and 50% for range 1,2,3 up/ down colors. how do i create color background alert for range 3 and range 2 up/down colors. i dont have sub graph numbers to refer to? |
[2022-11-26 15:36:09] |
Sierra_Chart Engineering - Posts: 18974 |
You cannot create Alert Conditions making reference to colors.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-11-26 15:36:15
