Date/Time: Fri, 28 Mar 2025 06:57:32 +0000
Tools Configs
View Count: 468
[2022-11-26 08:32:00]
User602969 - Posts: 9
Hi SC,
For Line tool configs, under tools inside Tools Configs, I have made changes to the line configs (opaque label Background), however, after I close my sierra chart or use the SC another day, the configs are back to before configs. Is this normal? How can I fix the problem?
Best,
Trader
Date Time Of Last Edit: 2022-11-27 11:48:13
[2022-11-28 16:26:39]
John - SC Support - Posts: 39009
Make sure that when you change the configuration that you are specifically saving it out by selecting the "Save" button on the window for the configuration. Otherwise you may not be saving the configuration. Refer to the following:
Chart Drawing Tools: Using Multiple Drawing Tool Configurations
Otherwise, you would need to ensure that you are able to write to the file named "Sierra4.config" in the main installation folder, which would be very unlikely.
