Date/Time: Fri, 28 Mar 2025 13:17:05 +0000
Aligned Renko
View Count: 448
[2022-11-25 18:57:55]
User379557 - Posts: 37
I have noticed that the Aligned Renko sometimes doesn't calculate correctly. Look at todays Aligned Renko and its identical to the Renko chart. Its as if it wasn't calculating the data differently from Renko. This happens at least once or more per week. Please advise. Thank you!
[2022-11-25 22:00:41]
Sierra_Chart Engineering - Posts: 18974
Is what you are seeing different than what is documented here:
Renko Bar Charts: Opening Price for First Renko Bar and Alignment (Aligned Renko Bars)
Provide an image of the chart or Trade DOM, by following these instructions:
