Date/Time: Tue, 26 Nov 2024 16:48:33 +0000
error 10061 connection failed
View Count: 1209
[2014-05-27 15:10:12] |
User88839 - Posts: 4 |
Hi I have realtime Sierrachart datafeed.Everything worked and suddenly data didnt work. Where can be the problem? Here is the log: Using username 0 | 2014-05-27 17:08:00 SC Exchange Data: Connecting to the server scdf1.sierracharts.com. Port 443 | 2014-05-27 17:08:00 Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2014-05-27 17:08:00 The network socket is connected. | 2014-05-27 17:08:00 SC Exchange Data: Connected to server. | 2014-05-27 17:08:00 SC Exchange Data: Sending logon request message. | 2014-05-27 17:08:00 Sierra Chart Server Info - Server Name: SC Real-Time Server. Server Version: . Provider Name: Sierra Chart. | 2014-05-27 17:08:21 Sierra Chart - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2014-05-27 17:08:21 Sierra Chart - Logon error from server : Not authorized. | 2014-05-27 17:08:21 Sierra Chart: Disconnected from the server. | 2014-05-27 17:08:21 Sierra Chart: Data feed disconnected. Will reconnect. | 2014-05-27 17:08:21 Using username 0 | 2014-05-27 17:08:23 SC Exchange Data: Connecting to the server scdf2.sierracharts.com. Port 443 | 2014-05-27 17:08:23 Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2014-05-27 17:08:23 Error received in OnConnect while connecting. Windows error code 10061: Nemohlo být vytvoøeno žádné pøipojení, protože cílový poèítaè je aktivnì odmítl. | 2014-05-27 17:08:24 SC Exchange Data: Disconnected from the server. | 2014-05-27 17:08:24 SC Exchange Data: Data feed disconnected. Will reconnect. | 2014-05-27 17:08:24 |
[2014-05-28 08:41:46] |
We apologize for the late reply. This problem was resolved yesterday.
