Date/Time: Fri, 28 Mar 2025 13:38:24 +0000
trading in indian markets using global data feeds
View Count: 327
[2022-11-25 16:08:12] |
negativecreep - Posts: 1 |
hi, just confused about one thing, global data feeds is a data service only, that means we can't trade using this, But in the global data feeds page, you have written no to trading and yes to automated trading. How does this work?
[2022-11-25 16:42:59] |
Sierra_Chart Engineering - Posts: 18974 |
Yes this is correct: global data feeds is a data service only, that means we can't trade using this,
Automated trading would only be for when using Trade Simulation Mode. So you can generate automatic signals but no orders will be placed and instead you would have an indication of them. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
