Date/Time: Sat, 03 Oct 2026 13:37:24 +0000
ACSIL: How can one get the LineNumber of an ACSDrawing whilst knowing only its Index?
View Count: 1854
| [2022-11-25 07:14:03] |
| User907967 - Posts: 54 |
How can one get the LineNumber of an ACSDrawing whilst knowing only its Index? Thanks, Bogdan |
| [2022-11-25 07:39:46] |
I found it. Here we go: s_UseTool ChartDrawing;
ChartDrawing.Clear(); for (int Counter = 0; Counter < 10; Counter++){ sc.GetACSDrawingByIndex(sc.ChartNumber, Counter, ChartDrawing, 1); sc.DeleteACSChartDrawing(sc.ChartNumber, TOOL_DELETE_CHARTDRAWING, ChartDrawing.LineNumber); } Tnx., Bogdan |
| [2022-11-25 09:58:17] |
| Sierra_Chart Engineering - Posts: 25042 |
Yes you can iterate through them by using this function: Using Drawing Tools From an Advanced Custom Study: sc.GetACSDrawingByIndex() Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
