Date/Time: Fri, 28 Mar 2025 13:24:05 +0000
Not Connected
View Count: 343
[2022-11-24 22:00:43]
User769294 - Posts: 2
Hi. How are you doing? My Sierra chart says not connected in red. I followed the instruction to link up with a data provider buy no use. I'm using the free trial by the way.
[2022-11-24 22:15:58]
Sierra_Chart Engineering - Posts: 18974
Connect to the data feed:
Select "File >> Disconnect"
Select "File >> Connect to Data Feed"
